SkipBurney
Do the IDI engines use regular head bolts or are they those sorry torque to yield POS bolts
Torque to yield? Is that where one of the two bolt heads twists off when it's tight enough?
The one I just took apart had what looked like standard, 12 point bolts. I had to buy some 12 point sockets. It's been a long time since I got into an engine.
Those are the correct head bolts.The one I just took apart had what looked like standard, 12 point bolts.
Factory spec is 100 lb/ft. I believe that I've seen people say they've gone to 110 but don't quote me on that. Even though they aren't TTY bolts, they can and do stretch some over time. The best bet is head studs.
That’s for the 7.3. And I did mine oiled just for a more accurate reading, but I don’t know if it’s supposed to be done oiledIs that for the 7.3 or the 6.9? I assume they have different torque specs?
Is that spec oiled threads? I know it's supposed to make a difference if the threads are lubricated or dry.
Factory turbo engines have different head bolts and were torqued to 110 ft lbs.
From what I recall, 6.9's were torqued to 80 lb/ft. Maybe 85?Is that for the 7.3 or the 6.9? I assume they have different torque specs?
