Harland Sharp rockers for the IDI
Clb
Another old truck
nannyfornia
Those are the ones you showed me when we timed your 6door???
To bad cuz them are purty in person!
Sux to see that issue.
Carl, yep the same ones i showed you.
Al, correct. they will get fixed, gotta install cam and make sure pushrod alignment is golden.
dont wanna correct one issue and run into another.
Cam, lifters, and pushrods mocked up
TahoeTom
S. Lake Tahoe, CA
Can they be swapped left to right on the shaft? Not seeing them in person I don't know how they are put together. I'm sure if it was that easy you would have already done that.
After messing with it, you were right Tom.
They were assembled incorrectly.
Most likely a dodge guy put them together.
I was able to get the shafts out of the roller bearings, swap shafts and everything looks ok.
I guess I'll find out when I shorten a pushrod.
Brian...is it an optical illusion or am I on the ball.
The rockers rollers seem willy nilly in depth...ones on far left seem to stick out more than others from body of rocker???
You should send them an invoice for fixing them for what I'm sure you paid for them they ought to at least be put together right.
Clb
Another old truck
nannyfornia
How does this happen?
Your product speaks for your business!
Bummer ya had to fix on them, cool you could!
the rockers are just floating.
no pushrods.
what youre seeing is some of the rockers not all the way against the valve stem.
Clb
Another old truck
nannyfornia
Keep on it!
Here's a'hopeing it all shakes out!
bbjordan
Snow Monkey
Ashern Manitoba
50/50 chance of getting it right. Sheesh!
Those rockers are obviously crap. Send them to me and I will dispose of them properly. :D
