Originally posted by Ggg
As was said, due to repeated discharges your batteries might not be able to take a full charge anymore. First have them load tested. Put a volt meter on the output terminal of the alt. and you should see no less then 13.6v while the engine is running at idle. The PSD can have batteries in "pretty good" condition and they will crank the engine over but there is not enough voltage left to fire the IDM. The IDM will not work with voltage less than 9.6v. Do you see any smoke from the exhaust? If so what color? Even with OEM batteries they will only be at worst 2.5 years old, I think that is a premature failure. Check with dealer on warranty. If the batteries load test good then have the GP, and relay checked. If no smoke then the IDM is not firing the injectors, likely due to low voltage. As far as good batteries go, I have had good luck with Motorcraft,Interstate,Optima. Optima are a bit pricey though. A hydrometer test to see if there any bad cells would be a good idea too, but most likely your battery is a sealed unit.
Ggg:
I should have clarified better that my cell phone killed the battery in my old truck so I just assumed that was the case the first time this happened but I haven't left the cell phone on charge since then.
When it's hard to start, white smoke bellows out once it finally starts. Normally it doesn't smoke any that I've noticed but, then again, I haven't followed myself.
I checked out Optima's website, and though I've read about a lot of people running Optima's, their website model calculator concludes that Optima doesn't make a model suitable to the 7.3l Turbo Diesel. Also, as I recall, the yellow top that most seem to be running has 750CCA and the battery I put in my F-150 last year had 950CCA. Seems like a lot to pay for a two year warranty and less CCA than other, more reasonably priced, brands. I agree the Optima batteries are nice looking and it's neat that they can be mounted at any angle but I'll never just sit and look at them nor show them off to people and if the angle they're mounted at is a problem then I'm likely not on all four wheels so......
I think I'll most likely opt for Interstate, if it comes to that, and be paying considerably less than the ~$300 that Optimas would be.
rvassar:
I have noticed in the past that when alternators are bad on ambulances, the voltmeter tends to jump around quite a bit when starting. I am aware that the dash gauges aren't all that accurate but mine is rock steady even when cold starting after it fires up. Our ambulance gauges were all added by our mechanics with instructions to ignore the dash gauges so the comparison may not be relevant.
