tonkadoctor
OK I missed somewhere the loss of oil in the hpop.
but before I would chase the hpop etc try a lp not gonna hert with the miles.
they are inexpensive and relaively easy to change, just being behind the balancer.
clearance is supposed to be .005 aor around there. the one i did has .024 clearance, It is possible yours is worse.
if i recall corectly the check valve on these is in the hpop.
will check more in the book at the shop./
I'm finding that the check valve drainback problems on the quick fill is on the early PSD now that I have done some more research.
LP pump and / or front cover is my diagnosis too, I'm mostly checking & testing the other stuff to rule out combinations of problems so I know what is working properly and what isn't, doesn't cost me anything but time which I have a lot of.
It's loosing the prime and not building pressure to fill the HPOP resevoir fast enough, worse on a cold start but will do it tooo on a warm start. Time to get it in and pull the LP pump & inspect the front cover.....IIRC the clearance is supposed to be .003 or .005, gotta look it up again..... .024 isn't good at all, that's close to 1/32nd of an inch I'm going to pull the pump and inspect tonight or tomorrow. Gotta charge the camera battery too, I have a bad feeling I'm going to find the front cover chewed up around the gearotor.
BTW, not looking too good when you talk to the Ferd sevice dept. receptionist because the diesel tech isn't there and she knows about the LP pump and front cover wear problems causing hard starting on the PSD
Gotta get my shop cleaned up and get the John Deere toys out of the way and the tools I have scattered from too many projects back in the box. You know you have too many tools when you can work on 4 or 5 projects and still be able to go to the box and get another of the same to work on something else.
Update @ 15:30......Fired it up after it sat about 3 hrs since driving it this morning.... plugged in too with temps around 59F today..... , fired right up and ran really nice for about 30 seconds and died, pulled HPOP resevoir plug and it's bone dry, exactly what I expected too...LPOP is having trouble getting a prime on this warm oil to refill the HPOP resevoir so I'm getting the shop ready to pull it in and pull the LPOP off.
I have witnesses too, right GEO
Was good to see you again, Mike
