H1 Hummer beadlocks
eastsideauto
Denton, NC
Anybody here running these on their truck? What have u done to overcome the crappy backspacing/offset?
Sent from my C771 using Tapatalk 2
A48WillyzGuy
Evansville, IN
I'm not running mine yet, but I cut out the stock centers and welded in new "pressed" centers to move the backspacing to 3.5".
Sent from my GT-P3113 using Tapatalk
I'd love to run em...just use standard Dual wheel front hubs and dual rear pickup axle and you can run em as is!!!!
JM2CW
Al
eastsideauto
Denton, NC
Are the center holes big enough to fit over the axle hub with no problems? I have heard of people having to have this center hole machined to fit over our hubs.
A48WillyzGuy
Evansville, IN
It's your lucky day! I just so happen to have mounted mine on my truck today and they look gooooood! I can't speak for the stock configuration, but these new pressed centers fit perfectly. The rubbers are Military Humvee Goodyear MT/R's as well.
fsr7
Boulder
I've ran them in the past with 2" spacers on each corner - that works as well, and it looked pretty decent.
Greg5OH
MI
JM2CW
Al
this is excellent news :D Guess i know what to add to my 4x4 conversion list, DRW hubs and dually rear.
Clb
Another old truck
nannyfornia
The 4x4 guys are doing recentered wheels with your choice of centers
Check pirate4x4.com?
Ya those are sick....
I"m just thinking the STAUN inflatable bead locks now...street legal and all, and selection of different wheel sizes too!
Mind you if I got a deal on some H1 wheels say 24 bolt style I could be convinced otherwise ;)
Clb
Another old truck
nannyfornia
Make shure ya get the NEW VERSION OF THE STAUN also a new name fer em
Pm me if ya want
Edit
The first gen ( will be used today) had sidewall issues! The 2nd gen ' units addressed this!
There is a po boy system using screws on the inner bead out there that is cheap( comes with possible slow leak potential) but on a wheeler it dont make a hill o beans as ya air up/down alot!
eastsideauto
Denton, NC
Did you have any problems rubbing on anything only using a 2" spacer?
eastsideauto
Denton, NC
Does anyone know if dodge 4x4 front dually adapters will fit our trucks? I have heard that they will but figured somebody on here would know for sure.
ryanecvbrown
Credo Quia Absurdum
Camino, CA
I have dually hubs on the front and 2" spacers on the rear. Awesome stance, perfect clearance and way cheaper than buying re-centered wheels. Also have the internal beadlocks so I can run low tire PSI off-road without issue.
Greg5OH
MI
pics!!
Sounds like if i just swap in a dually axle i wouldnt even need the spacers like you have.
MM battleship grey crewcab 4x4 on H1 beadlocks...would look aweosme.
radeon1314
