You should have small grounds from the frame to the cab at both front cab mounts. Should be one from head to firewall in the area of the wiper motor. Should also be a smaller one around the area of the heater core to the fire wall. For the life of me I don't remember what it hooks to. I believe there was also a ground strap to the frame from the front of the engine block.
How are you checking to see that you have power at the fuses? If using a multimeter is giving you 12v to the metal dash structure as a ground you should be okay I think. I would have suggested checking the fusible links at the starter relay if you have no power because all the in cab stuff is powered from there.
The big ground cable on the pass side battery should bolt to the block. Not the starter. Not sure what you have going on there. It should bolt here.
I bolted to the frame there because I relocated my batteries and they are both grounded to that frame rail. This is in place of the little ground. It was bolted to the frame in that location. I just made it a lot bigger to deal with the starter.
