Grease seal.
bucholzi
Norway, at 69' north.
Does anyone know where I can find an online source for a new grease seal for my two-part rear driveshaft on my 89 f250 supercab? Or a part diagram with parts numbers?
That is the seal on the slip-yoke assy at the driveshaft bearing, as per picture. ****** has exploded, and I have tried all my usual sources, and googled with no luck.
I didn't know there was an actual seal in this area. I just felt it was a felt type seal. Any driveshaft rebuild shop should have whats needed. Try a drive shaft shop. ?Surely they will be able to cross referance what you want.
RLDSL
Diesel fuel abuser
Arkansas
2nd a driveshaft shop. Just bring the shaft in and they should be able to pull the collar and clean it up and set a new dust guard seal on there. It will take a BUNCH of grease after
