GP controller: where does the ground strap go?
TwoTone IDI
ZF swap completed!
Richmond, VA
found a loose ground that is keeping my GPs from turning on. i have the strap with a small ring terminal... problem is the lead is VERY short and i dont remember where it goes.
does it attach somewhere on the manifold? only thing i can figure is it goes through the bolts that attach the controller to the intake manifold. does that sound right?
LCAM-01XA
my very own hell
One of the intake manifold bolts on the driver-side rear is where it goes, IIRC it's actually a stud and not even a bolt from the factory. If the wire won't reach there you may try grounding through one of the bolts that hold the controller to the intake, that should work decent too.
