Good Looking 6.9 Build on CL
jhenegh
Truck Still Earns its Keep
Deerfield, WI
This isn't mine and I'm still new here but this looks like it's well done. Is this somebody's on here?
http://huntington.craigslist.org/cto/3916081769.html
"1994 F250 ext. cab 4x4 210,*** Miles on truck. Less than 5000 Miles on 6.9 IDI fully torn down and built. Ground up build. New Main Bearings, Head Gaskets, Seals, ETC. Custom ground Turbo Cam from Delta Cams in Washington. Comp Cam 910 Valve Springs. Valve Job. ARP Head Studs. Diesel Performance Specialists in Michigan Turbo Calibrated DB2 Injection Pump(Flows 90cc's compared to 40cc's out of a stock pump/Governer Springs for 3800 RPM's compared to stock 3200 RPM/Internally Calibrated for Turbo). Diesel Performance Specialists Stage 1 Injectors(Claimed to be good for 25+HP/50+TRQ). Completely Rebuilt HX35 Turbo w/BD Diesel Performance Quick Spool Wastegate Diaphram. Intercooled. 3" Mandrel Downpipe/4" Straight Pipe/8"MBRP Black Tip. HD Torque Converter and B&M valve body shift kit. Dana 50 front end 4.10 with Superwinch lockouts. 10.25 Sterling Rear 4.10 Traction Lock. Rearend pulled and rebuilt 2 years ago. Every UJoint has been replaced. New Steering Box. New Carrier Bearing. 2"Add-A-Leaf Frontend Level Kit. 285/75/16 Mastercraft Courser C/T's65-70% on Eagle Alloys. Has Sony X-Plode deck and speakers and 10" sub with 200Watt Amp. GloShift QuadPod w/Boost,Tranny Temp.,EGT,Oil Press.
300HP/600LB compared to 175HP/300LB stock."
What do you guys think?
Wheelsrollin
