glow plugs
Bigfootpsd96
norfolk,va
i need to ohm out the glow plugs in my truck. would someone mind hooking my up with the resistance ranges and what pins on the connectors i need to connect to.
brandon
Mike
Stroker
Cora
Resistance ranges are from .2 to 2 with the lower being better. I think you are better off ohming at the GP itself so you take the resistance of the harness out of the equation. VC's are very easy to pull.
Bigfootpsd96
norfolk,va
yeah they arent bad......i was just trying to not take them off if i didnt have too....cus i know rotunda has the special adapter that u can just plug in and check the resistance. but i think if im gonna pull the vc's then im just gonna repalce them all. thanx stroker
geonc
SPIDER BAIT
NECKVILLE North Carolina
here's a pic......
reqasonable limits are .1 to 6 ohms using a DVM...if reading above 6 ohms or "OL" -open line- best to reove V/C and test both UVC harness and GP's.
Auto Zone has the Mototcraft/Beru{the ONLY ones to use ;Sweet } # ZD10 for about $10 each.
Hope this helps....
:cheers:
GEO
Mike
Stroker
Cora
geonc said:
ZD11.......... cookoo LOL
IDI's use ZD9 and OBS PSD's use ZD10
Glow Plug
(AutoZone) ZD-10 or ZD-11 (Beru plugs)
(Ford) F4TZ-12A342-A
(International) 1820697C2
The ZD-11 plugs by Beru are the preferred plugs in my experiences. Also 6 ohms is way to much resistance, maybe you meant .6? The higher your resistance the more amperage it consumes on its trip through th GP.
Ohms law is Volts = Resistance x Current.
12v = .1 ohm times unknown current. 12 divided by .1 = 120 amps.
12v = .5 ohms times unknown current. 12 divided by .5 = 24 amps.
12v = 1 ohm times unknown current. 12 divided by 1 = 12 amps.
New out of the box glowplugs should read between .1 and .6 ohms.
ajuka
