carrasco4712
9/10 times my truck will start only after 2 cycles. I let it go about 5 seconds longer than the WTS light (1st) time, then..I have to crank it within less than 5 seconds after the 2nd WTS goes out otherwise she won't start and I'll have to do the whole 2 cycle BS again.(this is 10 to 45 degrees temperature last couple months. I HAVE started it warm though, I bought the truck in CA and on warm (80+ degrees or so) days it would fire right up after sitting for 10+ hours when I'm at work. Or.. could it be air getting in the system. I know some of my seals are pretty crusty- I am changing them little by little. My idle sounds good but the tach. Sometimes bounces about 3-6 degrees.
Sent from my E6830 using Tapatalk
