glow plug relay/ controller issues
erikbala
Ride rank make Bank
Ellensburg/WA
hi guys i know this has come up many times before but im have trouble locating the treads.
any way when i go to glow the plugs the relay clicks for about 30 second giving the plugs inconsistent heat. im trying to trouble shoot this all the plugs are new and the wires are connected, i replaces the relay and still no fix. do you think it is the controller. if it is is it better to delete it and just put in a manual control, if so how do i go about installing one?
thanks for the help
mabc926
Mojo
Hidden vally
Do a push button and forget it, the 6.9 controllers are for the birds.
How I hooked mine up was, I hooked a wire to the + battery terminal and ran the other end to a momentary push button (like the kind you use for a push button start) and then I ran a wire from where the purple wire was hooks on the glow plug relay, and then the other end to the push button.
It's really easy, if you want I can get some pictures.
svttim
