getting 17v on volt gauge?
unclewilson
unionville tennessee
volt gauge getting 17v after battery replacement batterys went dead tryed jumping then replaced with two 800 cc batteries new. 91 f350. did i fry the alt/ reg?
1dieselman
Page,Az
2nd that on the voltage at the batteries. If it is that high get the voltage regulator replaced immediately before it hurts something
Dsl_Dog_Treat
Decatur,MI
17 volts...... bad.
As said, a voltage regulator you are in need of.
Andylad13
DieselBoy
Connecticut
Thats funny because when i have fried the voltage regulator, i never got a charge, never more voltage.
1dieselman
Page,Az
It can go either direction. I've seen a alternator charge so high it caused the battery to blow, thank the lord no one was leaned over it at the time
X3 Ya Replace the regulator before you blow the batteries, good thing they are new, old batteries could blow real quick, hell of a mess and might blind or burn someone badly.
14.2 to 14.5 volts should be max charging. Alternator won't last long either charging 17 volts
Cv axle
