GearVendors Overdrive with 7.3 C6 transmission, torque converter and output yoke
Status
Not open for further replies.
lotzagoodstuff
Carmel, IN
All coupled together, came from a running and driving truck. I bought this to install in my bricknose but now it's for sale.
Pick up in Seattle or I can possibly deliver it to the greater Portland area.
$950 cash
Thanks
Cubey
Van dweller
USA
Dang I could use the GV, adapter cone, etc for my RV's 6.9/C6, but I won't be up there for at least 6 weeks, unless I haul ass to get up there to buy it. I'm already slowly making my way up to the Tacoma area to empty my storage unit. Does it have the controller and all too? I wouldn't need the transmission (no way to store/haul it after emptying storage) so you could keep and sell it separately. Maybe I'll just haul ass up there to get it and forget some of my planned sight seeing...
Thats a killer deal just for the GV. compared to the prices I see on CL etc...
I have the same exact one I pulled from PNP at the end of OCT out of a 89 7.3.
Now I need the trans adapter for the T-19 trans.
GV charges around $700 for the dang thing.
Great deal if you get it Cubey.
Cubey
Van dweller
USA
Yeah I could really use it, even if fuel drops to $3 or less again. A 20-25% reduced fuel cost wouldn't take that long to recoup.
Dunno if they actually still have this available or not, but... it has the sleeve adapter too. They have a phone number at the top of the page.
https://transpartswarehouse.com/t19...-gear-vendors-adapter-w-sleeve-good-used.html
I have seen Transpartswearhouse before, located in Redding, Ca. They did have 2 or 3 listed last time I looked there.
HMMM...maybe a road trip up there? Might need a pass port or something to enter ****** land....
Might cost as much in fuel as the part.
Do some research, there is a deeper sump for the GV, think it adds another qt of ATF. Then as i read, they recommend to change the fluid every 5 - 6K miles.
here is their web site https://www.gearvendors.com/index.html
Here is a YT Vid I saved where the guy installed a Cummins in a chevy and the GV, pretty clean set up.
17 min video, shows how to shift it manually etc...
at the end show the under carriage how it is mounted.
Of course your van and auto trans will probably shift different. Think I read where you use a Head light dimmer switch on the floor to shift it.
Here is some info on installing it on a van. from genscriptor
Cubey
Van dweller
USA
Well it's free shipping so you wouldn't have to go anywhere.
A passport for... what? I have entered California twice in the past week. I ran into the usual ag inspection station on US-95 but that's it. Nothing on CA-190.
Yes the hi/low headlight switch is on the floor. That was common on vans. I had a 78 Dodge 1 ton van the same way.
Cubey
Van dweller
USA
I see fron genscript's site that you can make reverse safety lockout with a relay, and a manual toggle switch, so the controller can be done without. So I'd probably still get it even if it lacks the controller. Biggest extra cost will be shortening the driveshaft. 176" WB.
catbird7
PA
That would be an excellent addition to your rig and a perfect fit with all of the traveling you do annually.
Cubey
Van dweller
USA
I'll probably have to spend another $2000-$2500 to have it put in, so it might be a little while before I get around to it. Reason being, I might as well have the original C6 rebuilt (~$1500) while it's in the shop for having the driveshaft shortened. If I was going on my F250 with a rebuilt trans, I'd only have to worry about the driveshaft, but I'm planning on selling it eventually since I never use it, nor do I expect that I will much ever again. That or just have a shop install the GV and shorten the driveshaft and leave the 37 year old C6 as-is but after the GV install labor, I doubt it'll save much vs having the C6 rebuilt.
catbird7
PA
With current inflated fuel prices and the only potential "light at the end of the tunnel" at least two years away, you're likely looking at +$5.00 fuel for some time. Financially it's probably a good move.
Fixnstuff
Kitsap County, Washington
$950 cash
Thanks
I'll buy it right now. It's about 7 PM, I can't leave here until about 7:30 but could be at your location in about an hour and a half depending upon you specific location or meet you somewhere in Tukwila or along MV highway, or do it tomorrow if that's more convenient.
I left a message for you at your profile with a number to call or send a text to make contact.
Cubey
Van dweller
USA
Status
