Fuso Dump Not Going Up
Danielle
No, it's not finished
Dirty Jersey
Good customer, has all vans, and this Fuso. Stating his dump not going up. Anyone have hydraulic specs or know where I can find them? Or experience with these? 03 Fuso FE-SP 4.9L
fuso will not have anything to do with the hyd system. you need to figure out what system you have first. is the hyd system driven by belt off the front of the motor or is it driven by PTO off the trans? once you figure out the type of system, you then can figure out how the system is energized.
pics pics pics pics
more pics posted the faster we can work through this.
Dieselcrawler
Professional wrench holder
Quakertown Pa
could also be electric powered pump cal, depending on the size of the truck...
definatly need more info.
if needed, you can call me tomorrow. i wont be near ya, only in bordentown, but i might be able to help threw the phone.
Danielle
Dirty Jersey
You were right! Once truck here, it was electric. The ground!!
Almost like Mitsu made friends with VW and their ****** grounds
