fuel regulator ????
Goose_ss4
ca
I was just wondering what you guys thought about putting an aftermarket fuel regulator before the injection pump. I have my stock filter remounted underneath, and trying to run a steel braided fuel line from the lift pump, which is leaking, because of the stock hard lines are two different sizes. anyways I was going to put a new line, fuel regulator, and pressure guage as soon as I figure what kind if thread is going into the injection pump. secure everything with some nice AN fittings. let me know what you guys think.
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
What lift pump are you running? If stock, then you don't need a regulator. If you've gone to an electric and it's pumping more than about 9psi, then yes you need one. The fitting to the IP is an oring style and I can recall the size. There was a couple of threads here that listed it, maybe do a search.
GaryB
