So I just put a little over 560 miles on my truck and I averaged 14.125 mpg. That was mostly cruising down the freeway at 58-60 mph unloaded with the AC on.
My truck has a Moose pump turned down two flats, Hypermax turbo, Delphi BBs, 4.10 axles, Toyo 315/75-16 MTs, a 2-inch body lift and a 1-1/2 inch front axle lift. I religiously change the engine oil every 3K miles, the tranny/transfer case fluid is fairly new, the front axle fluid was changed about a year and a half ago, and I just changed the rear axle fluid. The biggest drag on my fuel mileage that I can see at this point is that I'm running a locked fan. The clutch took a dump and it was a quick fix, I'd like to install electric fans but have not had the time.
There was some discussion about my fuel mileage in another thread, and I'm curious what other people are getting.
Any recommendations to improve mileage? As far as I can tell my fuel system doesn't have any major leaks, but my filter head does weep a little diesel once in awhile.
