fuel leak
scheid6996
scheid6996
this time it isnt my truck, its a friends 96 powerstrike, with an auto, it has 150,000 mi, and it leaks a lot of diesel, so i started looken into it, and it looks like its comeing from the fuel pump right where the 2 hard likes come out of the back of the pump in the vally of the moter, so i pulled the pump, and the fuel filter canister, so i was wondering while i have it all apart what all i should replace? money is no object
jharvey
Shutter Bug
Georgia
Well if $$ are not object then get an electric fuel system in there, FASS or BDP, and some stage II 'jectors and monster HPOP, 6 pos chip from Twildman or DPTuner, the list goes on and on and............:D
Seriously, check the bottom of the fuel bowl for leaks as well, and clean out the Valley of Death, lord knows what you may find down there.
scheid6996
scheid6996
ya i found like 2 bolts and broken pieces of fuel filter cap, but he wants to leave the truck stock, but i mean what kinda hose do i need, part numbers for rebuild kits and should i get a fuel pump? and i need the metal washers for the hard lines
scheid6996
scheid6996
does internatinol have a web site i can order off of? what should i replace?
RangerDanger
