JwS
Hey all, I am going to install a turbo on my van. As I was looking over the install I came up with the idea of moving the fuel filter assembly from the top of the engine to a spot down underneath, near the fuel tank switch and my electric pump. If you have never seen a van setup, the spot they put the filter makes it a royal pain to change the filter, and adding the turbo only makes things worse. The only downside I can see to putting it down below is that it might be alot cooler down there, so it might be smart to run a heating line back there for winter use.
Any problems I am missing?
