You can never go wrong with howes, and dont believe the tests youve seen on the internet, theyve ignored the instructions ( as do most people) you need to dose the stuff at 3 times the amount on the label in a pickup or passenger car ( as you really should with most any additive) the ratio listed was figured for big trucks that flow oceans of fuel through the systeem and back through the return and just the return system on a big truck will keep the tanks warm once its been running a while, not so with smaller vehicles and with the lower volume comes lower lubrication, plain and simple, follow directions and you have a winning product, you will NEVER gel up and your system will stay clean.
If you havent run additives before, do not start running power service mid winter without having a whole bunch of spare filters on hand, it strips all the wax off the inside of your tanks INSTANTLY along with all the embedded crud and throws it to the filter, so as you stumble and cough to the shoulder, you know what it is, joust break out one of those new filters, fill it with clean atf, and pop it on and go till IT clogs, or just get the howes, and then all you have to worry about is draining the water out of your filter every night till you burn the first tank or so out. ( many years in a big truck in the great white north, and I've gelled up on every product out there at least once, except for Howes )
