rockbender
FS: IDI timing meter and tools (SOLD)
Hey guys - I sold my IDI E350 well over a year ago now and have finally recovered enough from that to part ways with my tools.
Rotunda timing meter for IDI diesel engines. It has the ability to check timing via both luminosity and pulse methods. I personally only used lumi method, but the previous owner used the pulse part of the meter and said it worked well. You need to have the injector line adapter that the pulse adapter clamps to (7.3's typically, but may be some 6.9's).
Also included in the package is a pump turning tool, injection line nut tool, injector seat facing / cutting tool, and wire brushes.
I've also got one new glowplug, 8 used injectors (they all worked fine when I replaced them), and a used CDR valve (not sure if it is good or not - I thought it was bad, but spent $80 on a new one to discover they both seemed to bench test the same). I'll include these parts too if they are of use to you.
SOLD
Also posted a link to a CL ad in that forum - the CL ad has photos.
SOLD
