Alright guys (and gals),
I'm picking up a 94 F350 for parts and I also have an 88 DRW F350 for parts. Both 4x4.
My 91 will be converted to 4x4.
I know the 88 should be kingpin and the 94 should be balljoint. Is there anything that would make one better than the other for a tow rig? The kingpin axle has the 4.10 gears I need, the balljoint axle is only 3.55 gears. I can swap if needed, just trying to decide if it's worth it.
I've also read that 95-97 have better brakes? Would it be worth tracking down a set of those knuckles for better brakes? Or are the brakes not really a big upgrade?
I'm assuming the DRW hubs should swap between the axles regardless of balljoint or kingpin right?
I'd like to do this once and be done with it. If I can spend just a little extra now and upgrade I will, but only if it's worth it. No point in throwing away money.
