Hydro-idi
Looks like the shop is going to keep truck another day. Even they can't figure out where it's coming from. Great
Well I guess you have two options. Tear it down and look for it or turn up the radio until it gets loud enough to drown it out.
Sorry man. This sucks but it's either going to have to get bad enough you can find it or you just have to go looking deeper. I'm not sure it's worth it on a fresh rebuild but I know it would be driving me absolutely nucking futs.
i know you said your advance solenoid isnt connected,
but..
did you try putting 12V to it when the ticking is present?
i also thought it may be a oil squirter not squirting at idle, but once you throw some RPM at it, itll work..
not too sure about that tho.
if you wanted to barrow my bore scope youre more than welcome to it.
Might very well just be the sound of the injection pump and injectors. Our fuel system is very noisy most of the time.
the next thing i would do Ian, is pull the front cover.
you say the ticking noise is coming from behind the harmonic balancer.
did you use new bolts on the waterpump, where it goes into the timing cover?
hell, pull those 4 bolts out and try again.
tryin to think outside the box.
