Just found this about the differences between Dodge and Fords...
"The newer Ford truck suspensions have pinch bolts which simplifies removal of the ball joint bushings. But do not assume the OE bushing has a zero degree offset. Many have 1 to 1-1/2 degrees of offset, usually in the camber direction. So if camber/caster corrections are needed, note the marking stamped on the OE bushing when it is removed so you can determine how much additional correction is needed. The first set of numbers stamped on the sleeve indicate the amount of caster, and the second set of numbers indicates camber. Subtract the numbers from your alignment readings to determine how much additional correction is needed."...
In the Dodge world, they're from another planet...
On the 4WD trucks, camber is preset at the factory. On the Dana 60 axle, the ball joints have a zero degree steel bushing, but on the Dana 44 axles there is no bushing. Though Dodge says no camber adjustment is available on either the Dana 44 or Dana 60 front axles, there are aftermarket offset bushings for the Dana 60 axle and offset ball joints for the Dana 44 axle.
Just food for thought...
