gatorman21218
Oh well the lawyers have to kill all the fun.
the TSB states that you MAY need to use an adjustable pushrod i guess you could use the plates together but i believe that would be overkill. this bracket is almost 1/8" steel so you shouldn't have any flex after installing it properly.
i got to look at the push rod i got here. i just changed the m/c on my truck. if its feasible maybe ill start making those as well. right now my main concern is to get the firewall plate confirmed that my parts are good and start making those first. i just bought a small sheet metal brake that will do 12ga so ill be able to cut these out and bend them up all in house and not have to outsource any of the fab work.
yes you can get in trouble with emblems and such...
im lookin at this bracket and lookin at my truck and cant see how its supposed to attach on the outside of the firewall.... you look inside under the dash and that looks right....
FWIW I agree with you completely...given that this is a known problem, may as well go for the big guns now and nip it in the bud. But, I can understand why someone would want the smaller plate (mainly for financial reasons, if someone's on a tight budget)...Personally, and not trying to start a war, but if I were doing one, even one that isn't cracked, I'd use the large one anyway...but that's just my .02 and nobody asked me!
