tuckerd1
WAR DAMN EAGLE!
And it wasn't too good!! I have a bad fuel knock on cyl 7 and it appears low IP pressure on cyl 4. I bled the air off each injector a couple of times. The truck started within a minute on first attempt.
Here are the symptoms. Am I on the right track here?
1. Engine knocks and is shaking violently,
2. If I loosen fuel line on all injectors one at a time they all squirt (spray) fuel around line thru nut except #4, I have some fuel coming out but not a lot. Makes little difference in engine idle or sound when I loosen fuel line.
3. When I loosen fuel line on #7, fuel knock goes away and engine idle smooths out quite a lot. Almost normal. Leaking injector?
4. If I rev engine to 2000rpm it runs fairly smooth, but it ain't quite right.
What do yall think? Am I forgetting to do something here?
