Lockedhearts
- Joined
- Apr 23, 2007
- Posts
- 173
- Reaction score
- 9
I have been looking for a truck seriously since July. I have posted on here a couple of times. I bought a brought home the F250 PS I wanted. It has been sitting for a couple of years. I had it towed home. I started last night charging the batteries. Had to work today, so this morning moved charger to second battery. Stopping after work to get Air Filter, AntiFreeze and oil to change that tomorrow. As I started charging the first battery, the key apparently was not in the off position and the glow plug relay was clicking, so at least I know there that part was working.
I plan on changing the CPS as well . I have not gotten a clear answer as to why the truck sat for a couple of years, so it may be nothing, it may be something. I do recall, when I looked at it back in April, we got enough out of the batteries then to see the front fuel tank registered almost full.
Since it has sat and we have had wetter and colder temps than usual, should I be concerned about the full in the tanks? I generally use Sea Foam as an additive, did that routinely with my 91 350 with the IDI. I will take Before and After pics and post , gonna take a good bit to clean it inside and out from sitting under trees... UGH!
Hubby commented it had the floor mats in the bed,well those are getting tossed and my good John Deere mats are going in it Tires are awful, if there is worse than a Maypop, this truck has them! BTW, I thought it was a 97, it is a 95, but that is fine too.
