Saskredneck
Yeah I know a thread about filters... Just curious on what most people are running for filters on their IDI's? I've switched over to fleetguard filters (cummins) because I get them cheap from work and don't have to drive into the city at all plus there are numerous filter heads I can use when I delete the stock fuel filter and water separator, having a hand primer is going to be nice come filter changes! I have been a long time supporter of wix and have/are using them on all my gas powered fords but will be switching to fleetguard as well for the convinence of going to the parts department at work and getting it. Filters to avoid? Personally I won't put any Fram filters on anything I own, tried one the first weekend I got my diesel because it was a couple day wait to get anything else and the thing leaked just like I seen many frams do when I worked at ford and has customers come in saying they changed their oil and its leaking now. Haven't had any luck with penzoil filters either seen a lot of the same garbage as the frams. Motorcraft are great but getting them is a hassle for me so that's why I don't run them. Also noticed the oil comes out a lot cleaner and isn't nearly as thin when using good filters like wix or fleetguard compared to cheaper ones.
