FILP Wires
02x72
Des Moines, IA
Im installing my new Baumann controller and am hooking up the FILP wires, but the new clip from napa just has three white ones. I found a while ago a page telling which ones they are, but cant find it. Can anyone tell me which is the ground, feed and output signal on the sensor. Maybe in a bottom, top, middle wire description. Thanks.
trackspeeder
Stone crusher.
North Branford. CT
Holding the connector facing up. The index tab is bottom.
Terminal 1 Signal return.
Terminal 2 Throttle position.
Terminal 3 VREF
Center green wire is the throttle position and it send voltage signal to cpu.
