beretzs
Alright, sorry I haven't posted in awhile, but the last time I drove the truck last weekend, I drove up some really big hills unloaded, which usually the truck flys up with no troubles at all. This time it got pretty warm, up in the 230* range. Then even once I got back down on flat ground it was still running a little warm. When I was heading up the hill, I had my windows down and could feel the coolant mist on my hand (not alot) but enough to notice. Well, after I finally got to flat ground it ran back to normal temps, but if I pushed it very hard, it would warm up quite a bit. Never really had a cooling problem, but I have one now. All the way going up those big hills, I cannot remember the fan clutch kicking on, clue number one. But then once I was on flat ground it was still running warm. Just for notes, it was about 75-80* outside, so that should not have been affecting it too much. I guess, I will have to do the fan clutch test, and maybe think about a new radiator too.
Anyhow, by the time I got to where I was going, I was about a gallon low on coolant, and I am thinking that it is because of the truck pushing all the extra into the coolant res and it overflowing. I was going to take it back up to the shop that did the headgaskets, but I am just wondering if it has anything to do with the headgaskets. I am kinda doubting it is the HG's since I have been running it fairly easily, not running over 1000* EGT, so I am thinking it has to be something with the cooling system. Radiator has alot of crap on the inside, not sure if it needs cleaning or what. I would rather just put a good 4-5 row radiator in there and be done with it. With all the extra power, I am not sure the stock radiator is up to the task of cooling the engine effieciently anymore.
So, if you guys have the link for the MS Tech Clutch fan, and good hookup for radiators, I would apprciate it. Oh, and on top of that struggle, I have a rear wheel seal leak. Gotta change them ASAP. This coolant thing has me bugged, the truck was running GREAT until I hit those big hills and it spilled coolant. Anyhow, any good feedback is really appreciated.
It does have the IH stat in there, just put a new one in when the HG's were done. So hopefully that is covered. Scotty
