So whilst this is on my psd, a lot of it is the same for the obs idi trucks. (From what I could find)
I have the factory trailer brake plug under the dash. Which apparently when the PO picked it up from the factory, didn't know there was such a thing. So basically the wires have been spliced and ran every which way. I've fixed a few of them, but will be buying the adapter. Tekonsha 3035-P Brake Control Wiring Adapter for Ford https://www.amazon.com/dp/B001NZQIDE/ref=cm_sw_r_cp_apa_NY2kybD4VMCYK
Will most likely be replacing the controller also.
Now for the question part. Lol at the rear of the truck, I don't have the added wiring. The trailer plug has been spliced from the other wires. No adapter harness. There's a wire from the controller ran back for the trailer brake. Is there a factory wire in that under dash plug that already does this? Which I would try to find the rear adapter harness also. (If it's still available, I haven't found much information on this yet.)
Also I don't have the extra under hood relays. But I read one guy said he found the relays and box in a junkyard, and it plugged right up. He said the plugs were just capped off or something. (I haven't really looked on mine, but I do know there's some extra plugs in that area)
