Hydro-idi
I recently got my new engine back in truck and took it for a test run yesterday. Everything seemed to be working well aside from engine surging at idle sometimes. I started investigating what could be wrong, not knowing where to start since everything on my rig has either been replaced or rebuilt. I just happened to look at this aux. pump that had a hex cap on the bottom. I only use this pump if I have done work on the fuel system & air is present in lines. I did some research on this pump & found out that there is a filter element in it.
I took filter out this morning & found that it was completely clogged & caked with dirt and rubber pieces from the tank pickups. Couldn't believe it even ran like that and probably hasn't been cleaned in 10+ years.
For those who run a facet filter like I do, just a friendly reminder that there is a very fine mesh filter that should be cleaned periodically. Sure does run good now .
