Facet Duralift #40223
mikeboggess
Texas
Ok, I beleive it was DesertBen44 that had some info. on where to buy this fuel pump. The best price I can find now is nearly $150.00, Any body got a better (cheaper) source?
rdoimages
Kingsland, GA
What's the difference between the 40223 and 40222? Specs look alike.
89 F-350 sc 2wd DRW 7.3 ATS 088, C-6 with Gear Vendor and a rats nest of wiring that was free with purchase.
00 Excursion limited, 6.8 4x4
rdoimages
Kingsland, GA
I see one has positive shut off valve and the other doesn't, not sure what that means in practice.
See how helpful everyone is here.. Thats what makes this site better than the rest.....:hail:hail:hail
I thought the difference was one had a connector and one was bare wires but maybe that's a different number. :dunno
gandalf
Senior Member
CA &/or Maine
Interesting. I'm moderately sure I have the 40222. You can see that it came with the cable end.
attachment.php
attachment.php
attachment.php
Says 40269 on it. Difference according to looking at the specs is that the 40223 had a connector and no positive shutoff. The 40222 has no connector but has positive shut-off. Both have check valves. Not sure what positive shutoff is in this situation if it has a check valve.
www.aftermark.net
mu2bdriver
CT
...had a connector
I have one with a connector. It's called a Packard connector - female on the pump - and you can use Dorman part number 85390 - male counterpart. Works great and easy to disconnect if you need to move the pump for whatever reason.
MadScientist
