F350 Leaf spring material?
Rawpower
'Froading Freak
Rep. of TEXAS
Anyone know what steel is used in stock F350 leaf springs?
Would it be 5160 alloy? :dunno
Thank you,
Rob
Rawpower
'Froading Freak
Rep. of TEXAS
It should be 5160, perfect for bladesmithing... but I'd like to find out before I ruin a perfect set of stock leaves haha
sassyrel
iowa
I don't know what grade it is, but I DO know that it eats drill bits alive.
turn the drill bit----------R E A L slow--and use lube, and youll drill thru--the rockwell between the bit and spring aint much----unless its s super hard spring----
MARQ2277
caldwell, idaho
I just use Colbolt bits, and not worrie about it. (Or just puchase the colbolt bit size you need, 'cause they do cost.)
Marq
_________________________________________________
1990 Ford F-250 4X4:
7.3 IDI with 120K on the clock:
ATS Turbo with waste gate:
Stage One Injectors (Oregon Injector Service):
Complete Return Fuel Kit (Oregon Injector Service):
DB2 Pump, cranked up with Cold Advance wired permanently on:
4” down pipe, 4” straight through exhaust stopping between cab and bed (no **** on my stuff):
Torque Converter Lock Up Switch (On/Off/Lock-Up):
E4OD Line Pressure Controller (adjusted to fast/firm shifts):
4” lift w/Rancho shocks:
Big Fat Tires on custom rims:
Tows 1985 fully loaded heavy 28 foot RV (my house) everywhere:
You're going to make a sword out of one? :eek:
LOL
Ask for a leaf from a bad pack. Don't ruin a good set - somebody may need it. ;Sweet
Rawpower
'Froading Freak
Rep. of TEXAS
LOL
haha no just knives... one leaf can make about 30 or 40 knives, so I'd be cutting up a pack just for one leaf out of it. Right now I'm just using the overloads, but I'm afraid they will retain too much of the memory
As for somebody needing them, I've had them in and out of my sig line for the past 2 years and nobody has even asked about them, but yeah I'd rather get a leaf out of a cracked pack or something from a junkyard and let someone on here use my packs
I hate colbolt bits, I've never had good luck with them. Good old fashioned ones with cutting oil have worked far better and longer for me
Mr_Roboto
Elyria, near Cleveland Ohio
The spring leaves break because of the spacers Ford uses between them to "soften" the ride. They create a shear point in the leaves.
When I rebuild the spring packs I remove the spacers.
Alleycat
