f250 front brake rotor removal?
GREASE FIRE
Falmouth KY
are there any pictures on this forum of how to remove the front brake rotors on a 4X4 f250?
i started off today just planning to replace pads but now i find the caliper and rotor on one side are both shot and i can not figure out how to remove the rotor. any help greatly appreciated!
thanks,
Paul
hairyboxnoogle
Nampa, ID
pull the wheel, pull the caliper, take the hub off, use an air hammer to knock the wheel studs out and it should come off with light persuasion. That is if im remembering the right front end, been a while.
robmoore11
surrey bc
thats exactly how it works.
1.take caliper off.
2. take out allen bolts on outside of hub.
3. remove clip, it is one of those annoying ones that you have to use a screwdriver to get out.
4. there are special nuts that you are supposed to use a special tool for but i just used a small hammer and a flathead screwdriver. there may be c clips before or after i cant remember.
steps may be a little off its been a while since i did my brakes. but i would get a c clip remover tool. for inner and outer.
Lance
