I like my air to air!
and if I ever do a inline engine swap, it will be a DT
Mike, that link does not work for me.
https://www.oilburners.net/threads/electic-fan-clutch.70947/
Does this one? The old one worked for me.
Wouldnt go with an electrical fan. They are junk and don’t move enough air for these beasts.
When I did my water pump I got a new motorcraft fan clutch from rock auto I think? Either way when I was idling twice with the a.c. on my water temps went up to 220 while sitting in the city. That never happened with the old dirty one I pulled off and it wasn't locked solid.
I did also put in a new thermostat so maybe my old one stayed open partially or something but if I ever have a cooling issue that's legit i might toss the old fan clutch back on because this one seems suspect after like two weeks. Haven't felt it lock once yet even sitting at 220 that day.
the only problem with this is that the only viable stretch of road I can really push my truck is over an hour away at 80 mphI dare one of you guys to do some testing with the hood on, then repeat with the hood off.
