funnyman06
So i was tired of the stock exhaust and yesterday decied i was going to cut it off and install this flowmaster i had lying around. Its a 3 inch in and out 50 series, its about 3/4 the length of the stock ford muffler and half the weight. I cut the exhaust about 2 feet from the exhaust flange. Then i run a 2.5inch to 3 inch adapter with clamps to the 3 inch pipe and about 2 more feet is the muffler. Unfortunily the stock tail pipe was about 4 inches too far the to passenger side so i cut it off too. Now im looking for a turn down so the exhaust goes towards the ground and not my rear end.
Im also thinking about moving the muffler closer to the front of the truck and then running the exhaust out the side by the passenger side rear wheel. But if i do that im not sure how i would support the muffler up. Muffler was used came off a 7.3 IDI so it had the mounting hardware set up almost perfect. Sounds pretty good, but now the exhaust sounds like a big block gasser and less like a diesel. i know most people say dont use one, but i had it so i put it on. Truck seems a lot more peppy then it did before. So this should hold me over till i can get a real diesel exhaust for my truck, looking at the dynomax system, comes with new y pipe and 4 inch tail pipe. I will try and get sound clips of it, just need to find a camera.
