LCAM-01XA
Most prefer electric gauges for the convenience of being able to install them anywhere they feel like. With mechanical gauges, if you have a concern about hot coolant spilling all over your cab should the line rub, that's not how they work - worst that will happen is the gas inside the line will vent and the gauge will drop to zero, as coolant never really leaves the engine. Mechanical oil pressure gauges on the other hand, oh yeah, them things can and will pump hot dirty oil all over the place if they let go - there are "gauge isolators" made for that very reason, but since it's usually their feed line that blows just using a simple steel-braided high-pressure line more or less takes care of that issue.
Bottom line, it's your decision, either type works. But e-gauges can be had in number of styles, including ones to match your factory Ford gauges on the dash. If, that is, you care for that.
