Engine fire
Patriot304
Bells Tennessee
Allright so I went to napa today and got a reverse drill bit to remove my stuck gp. They told me to warm my truck up b4 I tried to back the glowplug out. I got home plugged my truck up for a couple hrs then tried to start it wasnt gettin it so I gave it a couple shots ether. Cranked up. When I came aeound to the front of the truck there was a fire under the intake. Is that from the other or what? Any help would be appreciated. Learned so much from this site.
david85
Campbell River, B.C.
Might have been a backfire through the intake. I hope you didn't blow the intake manifold gasket in the process. Hard to say without further information or pictures. Hopefully you got the fire put out before any damage was done.
Philip1
Northeastern Nevada
was the fire in the front of the intake or the back? turbo or na? it was most likely a backfire from the either or maybe a shorted glow plug controller/ wiring depending on the location of the fire.
rhkcommander
Oregon
Definitely ether, probably didnt unplug the automatic glow plug relay
I'm not 100% convinced on the ether part. Actually, I'm thinking ether in a different way. I don't remember any mention of a backfire. Some of the wording in the original post is odd to me, but I'm getting used to it. The OP said that he tried to start it with the block heater, "but it wasn't getting it". I assume that this means that it didn't start after the block heater being plugged in for a couple of hours. Then, with the ether, it "cranked up". To me, this means that something is turning over (like a starter cranking), but am learning that some people say this to mean that the engine started running. After that, I doubt that it would be an ether fire. The engine was running when he saw the fire and there wasn't (assuming) a backfire. If there had been a backfire, I could see where there may a small possiblity to light some of the oil from the CDR on fire. Either way, I would think that the air going into the intake should draw the fire away from the "fuel" and put it out. My guess would be that the glow plug wires were still disconnected at this point, but the system was working fine. Since the OP said that it was underneath the back of the intake and not inside it, I'm guessing that a glow plug wire was laying on something flammable. Diesel fuel? oil? penetrating oil? an over shoot of ether? When the ignition was turned on, here came the heat to start the fire. Now there was no mention of whether or not the ether was sprayed into the factory air intake at the front of the truck or directly into the intake manifold itself. Now "a couple of shots" of ether into the intake manifold should cause preignition of the ether in the engine if it all went into the intake manifold, but again, no mention of this either. So that makes me think that the first shot of ether could have missed the intake manifold which is easy to do, especially if you're in a hurry, like I'm guessing that he was. Of course I may be way off the mark on all of this and may be completely wrong. I just like to think outside the box sometimes if what's inside the box doesn't make complete sense to me.
Patriot304
Bells Tennessee
Thanks for the help. Pretty sure it come from gp harness wire touching penetrating oil.
Sorry idibroncho for my poor writing
Some people say things differently than I do, but I can usually figure out what they mean. I'm glad to hear that you're pretty sure what caused the fire.
