69oiler
I don't feel tardy
i'm double checking the location of that all-important number that tells if you have an old or newer style 6.9 (and if the block heater area is weak or not)
from what i know, this number is located on the top of the block, near the timing gear cover, on the right side. it looks like this...
i forget the actual cutoff # but i want to say it's around 17x,***. lower numbers are prone to cracking around the block heater and higher numbers are not. am i correct?
