TWeatherford
Life has been insanely busy lately. I've been out of the country for a week, truck parked at home, Dad thought it would be hilarious to wire up an electric air horn like he has (which I detest) on MY truck. Stripped insulation off and soldered a lead into a wire next to pass battery (supposed to be the connected to factory horn), couldn't get enough juice with the horn on (like 1-2 V) to make it work. Left it like that. I was mad, cut the wires he added, taped them off as best I could, and headed out 180 miles back to college. No tachometer (although it moves slightly while cranking), when the headlights are on my right turn signal indicator is on (not blinking, just illuminated). Right turn signal works when it wants to, sometimes very slowly, sometimes not at all, sometimes just fine. I can only assume these problems are related, because all was well until someone messed with something. Any ideas on how to fix? My normal horn works fine. He better not try anything like this again.
