I installed a dual heated filter assembly and decided to ditch the stock filter assembly in order to reduce fuel flow resistance. All of this is part of my WVO setup. Anyway afterwards the truck refused to start! I read the idi tech article on hard starts by Agnel and he mentioned that he relocated the fuel filter under the truck and he runs his electric lift pump with the air bleed hose disconnected on the injector pump. Well after reading that I did just that but by cranking my engine since I don't have a electric lift pump. So what is the best electric lift pump for use with WVO? Because if I ever run out of diesel I don't want to run my batteries down trying to bleed the truck so it will start if I can just let the electric lift pump run until fuel comes out of the injector pump bleeder and then just put the hose back on. Part numbers would be great!
