Electric fuel pumps
Farmer Rock
Glen Rock,PA
IIRC,The only in-tank pumps were for the gas trucks.I have to ask,why do you want an in-take pump,when you can have an e pump that is separate and easy to access?Also, the in-tank pumps,aren't rated for diesel.
Rock
Ford diesels didn't switch to electric fuel pumps until the '99 model Superdutys came out as far as I know. Even the OBS PSDs had a mechanical lift pump although it made much higher fuel pressures than our on our IDIs do.
