I can't do that.... I made sure I had a pyro BEFORE it ever towed anything!
The DP is definitely on my to do list now!
You need a boost gauge too.
I would begin looking for boost leaks, you should be able to make more than 10psi without running into egt trouble
What he said.
You have leaks someplace.
The boots to the plenums are the leakers in most cases. They get soaked with oil and crap. Then start to crack.
There is a gasket that seals the plenum to the head.
I found all the hoses I need and got them changed. My boost numbers went from 3PSI at 70MPH on the interstate, to 5-6PSI on the same stretch of road. I've been able to max the boost out at 16-17PSI, when I put my foot in it.
I also changed out the crushed DP, in favor of a 3" DP. I haven't towed with it yet, but was only able to go a bit above 1200* while climbing a steep hill, about 2 miles uphill.
I already have the 6637 intake and the cat delete, so the only possible thing left to do (That I can think of) is gut the EBPV.
does this thing have a chip in it?
Shouldn't have to gut the EBPV on a stock PSD. If EGT's are still high, you have other problems.
