stumpjumper3
I recently got my isspro pyrometer installed on my truck. It is installed at the number 8 cylinder in the manifold. My truck is still na, good reman pump not turned up, bb code objectors and return line kit from typ4, the pump is not timed yet. I noticed on my last hay run, I had right at a ton of hay on the flatbed. I have a very good grade to pull on my way to and from where I get my hay, well I had it in 4th and not really lugging the engine at all, I'd say about 2600 rpm and pulling hard.
Well my egt's climbed up to 1300 degrees and would have probably kept going except I slowed down and dropped a gear. Now I couldn't accelerate but i was not losing anymore ground.
I have removed the soup bowl and a k&n filter. Now I have a dual exhaust on this truck. It is a 2.25 all the way back, and its got some what looks like turbo mufflers on it that are pretty darn quiet.
I have been trying to think about how my egt's got that high. My thought, is perhaps the mufflers might be plugged, causing excessive heat to get trapped in the cylinders thusly not letting the engine exhale quickly enough. Does this sound like a logical reasoning? Or is this normal and i was just lugging the engine too much.
Now I was given a cat back system from a 6.0 and its a 3.5in all mandrel bent exhaust. I was thinking of getting the dynomax y-pipe and installing this on my truck to help it exhale better. What say you all?
