Easy Headlight Upgrade Kit?
laserjock
Almost there...
I would think that would work. Terminate your two wires in the harness for the hi and low beams to switch the relays... yea... I could see that working. Maybe not as tidy as a relay block but it is cheap.
84TD
Virginia Beach, VA
What is a relay block?
Looking at all this stuff to fix the wiring in my truck, I want to tidy everything up. Going to install a secondary or maybe a third fuse block and eliminate as many cheap butt connectors as I can with quality 3M ones with the built-in shrinkwrap. Also going to do the headlight mod and add some relays, switches and lights.
Doesn't help much that I have three different wiring harnesses from three different trucks all spliced into one plus all the accessories added over the years!!
Cv axle
