Early sidewinder E4OD to ZF5 differences?
6.9poweredscout
Bleeds IH red...
Northeastern Pa
judging by the steady stream of ATF pouring from the pump seal on my E4ohno i'm assuming it's telling me its had enough..... :puke: i noticed on the banks site there's different listings between the auto and stick kits. will i be able to swap a ZF5 without having an issue with the turbo?:confused:
justinray
Contributor
Cleveland, Tx
I *think* the only difference is that the auto version comes with a transcommand and a different dipstick tube for the trans.
hesutton
The Anti-Anderson
Bowling Green, KY
X 2!
That is true with the wastegated version at least. I suspect there is zero difference in the plumbing for the early Banks system as well.....
Heath
Dsl_Dog_Treat
Decatur,MI
Actually the early Banks kits are trans specific. The ZF's have a deeper bell housing that the E4DOA's.
I had to do some serious exhaust rework to get the exhaust to work on mine.
jaluhn83
Upper Marlboro, MD
As said above, the early ones that route the up pipe on the driver's side are different between auto & stick. The manual bracket comes back about 1/2" further and then drops down to allow clearance for the thickness of the manual bellhousing.
The later type use a cast y-pipe on the passenger side that hugs the aft face of the block and shouldn't have any clearance issues. I do know you have to cut one of the 'ears' off the zf-5 case for clearance but that's not hard.
90idi4x4
Ohio
I have an early banks non gated sidewinder on my truck now that was out of an auto. Mine has the zf in it and i paid a local shop to custom make the uppipe so it would work. My firewall took a beating and i had to put my reverse lights on a toggle because the harness is on the drivers side of the trans. It works well and it isnt squished like the banks one is. From the picture i got from banks with manual kit the uppipe goes up on passenger side.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
Never posted a pic of the turbo kit i have. it's this one:
is this style still a pain in the ass?
hesutton
The Anti-Anderson
Bowling Green, KY
Jon, like stated, that's the new wastegated style. The plumbing is the same regardless of the transmission.
Heath
GaryB
