cowman79
I am starting to have some trouble with my trucks torque converter not locking up properly. About two months ago it didn't lock up when i first started driving then after it would warm up and it would start locking properly. Now it is almost every time I drive it that it doesn't lock up properly. I can drive the truck for several miles and it will start locking up properly. I can turn the truck off get right back in the truck and it will not lock properly. I have a transmission temp gauge on the truck and the lock up is not dependent on the actual transmission temperature. I feel like this is an electrical problem but not sure where to go from here. The truck is not showing any codes. The transmission was a low mileage transmission that was put in about 6 months ago. The truck shifted seamlessly for a few months and then started the unlocking problems that I had before the transmission was put in the difference is that before the transmission was put in it was throwing codes. I think this was related to a bad connection on the PSOM because I disconnected and cleaned the connections on the back of the cluster and it quit throwing codes and started acting properly until recently. The transmission was replaced because the torque converter had destroyed it self after towing a large load of lumber.
