Okay, I'm home from work. There seems to be enough interest, so I'll paste in that old post. Understand, it's not my post, and I can't stand behind it. I have not done the mod, I don't know for a fact that it works. Some of our better people can figure out whether it will work, and how to make it work better. This is from 2003, so it must be TDS.
BossTrans
Member
Member # 27254
Reged: 12/08/02
E4OD lockup Modification #1124277 - 03/15/03 10:17 PM Edit Reply Quote
For those who would like to convert there lockup to a manually controlled status via a two pole switch, the following will apply.
I post this information for peeps that Who do not want to entirely reverse engineer thier lockup circuit. Thus was the case on one of the vehicles brought to me. This mod was performed and works like a charm on an ambulance that had intermitten lockup problems. Intermitten lockup causes heat and convertor failure. Ideally in this situation the vehicle could be diagnosed by Ford with minor difficulty. However, It is my luck as is some of yours that the problem cannot be picked up my scanning the rig for faults. Poor grounds or dirty connections do not display themselfs on scanners. This vehicle we worked on has a 9"x6" wiring harness in it. The process of reverse engineering that bad dog was unacceptable so we went to Ford. After shelling out big bux to Ford to say "we dont know where the problem is but we can keep working on it (for 65 per hour!)" We decided to mod the trans harness ourselves. You should have a multimeter available to you before performing this mod.
The E4OD in my opinion shifts like crap from the factory. Lockup engages in all gears somewhat randomly and really gives unpredicatable results in shift feel. There is a solution but it is not for everyone. Several companies make trans command adapters which work nicely if everything in the vehicle is electrically tight. If there are connection problems in the vehicle regulating lockup circuit the trans controllers will not work. So the only other option in curing this problem of shift feel revolving around intermitten lockup and wireing problems is to install a manual switch to bypass the computer controlls for this circuit. DO NOT LET THE WIFE OR KIDS OPERATE THIS VEHICLE WITHOUT THIS SWITCHED MARKED "KEEP THIS SWITCH OFF." If this switch is left on below the speed of 25 the vehicle will shake and you may leave parts of your trans or engine behind!! This Switch cannot be placed in the "on" position until the vehicle speed is above 35 for most effective shift feel and control. For guys that want that control over shift feel this really does work great and should improve mileage for those who experience lockup cycling. Lets begin.
Identify the Main electronic harness going to the trans. Above the trans connector about 4-5 inches locate the Purple wire with a white or Yellow stripe on it. This wire gets stained with oil so look closely. Simply cutting this wire will make the trans shift through all the gear ranges except for convertor lockup. The trans will at this point shift better then u have ever felt before because the gear ratios are all nicely matched by ford. Early lockup screws up this nice ratio thus this fix will eleminate this.
Now that the lockup wire is cut attatch 2 lengths of wire to the two wires that are now available at the trans (one length per each lead).
drill a small hole in the floorboard under the carpet to get the two wires up to your dash somewhere convient for a switch. At this point u need to do a test. Tie these two wires together. The trans should operate normally and lockup will come in as before you cut the wires. At this point all we created was a loop effectively lengthening the path of the convertor lock up circuit. Using your meter, and a second driver for the rig, get up to about 55 mph and hold steady. Set your meter to dc voltage on the 20 volt scale. Place your red lead to the two wires on your dash that are tied together and the black lead to the outer circle of your cigarette lighter (ground). At the speed of 55mph with the vehicle warm you should have a reading of about .5 to 3 volts. If you apply the brake and hold the speed at 55 you should see that voltage jump to 12-14 volts. If you let off the gas the voltage should be 12-14 volts. As you get back on the gas and return to 55 and level out you should see the voltage drop to .5-3.0 volts. With the vehicle in park the voltage should again be 12-14 volts. You will notice that when lockup engages the voltage drop occures and lockup takes place. We are going to manually drop this voltage by adding a ground which is effectively what the computer does to engage lockup. If these results are not typical of your vehicle STOP HERE!! Your harness may be different and this Mod will not apply to your vehicle.
Assuming your tests indicated the correct results and u have the two wires inside your vehicle, open up the two wires you tied together and place the red lead on one of those wires and the black lead to the cigarette lighter outer ring (ground). You should notice that one lead will produce 12-14 volts with engine on and in park and one wire of the two will produce .5-3 volts when measureing to ground. Note the High voltage lead. Take your switch and place the high voltage lead reading 12-14 volts on one of the switches poles and tighten it down. On the other side of the switch connect the remaining wire from the trans AND a jumper wire that is somewhere securely grounded to the chassis of the vehicle. This will in effect ground the second terminal to the chassis. The benefit of this arrangement will gives the driver total control of lockup. Notice that when the switch is open (off) the computer cannot engage lockup if it is undesireable to the driver and around town you will get nice crisp shifts that contain nice ratios as designed by ford. Once this switch is activated lockup will engange and HOLD for the duration the switch is on.
I recommend you only use the switch for highway use to increase economy. That is unless your like me, I like the ability to control shift feel and it doesnt bother me to toggle that switch off and on for stops. If your a control freak this is the nuts and works well. This mod was performed on a 91 Diesel ambulance converted to a service truck. As we have not tested it on all electrical configurations for each of the years we cannot assume that this mod will work in all applications. For those of you that it does work for, Enjoy....its a really nice feature that will payoff in economy. On the highway flip the switch and let her go!!! even if you let off the gas a little lockup wont fall out and then reengage like the factory controls. Once Boss Transmissions web site is back up we will provide schematics for those who would like to review the above procedure.
We make no claims about its intent or use. Perform at your own risk. Feel Free to Correct anything I have said here. Read this Thread thoughly incase others experience situations that are undesireable. Thanks for your time..
Dan from BossTrans
Post Extras:
yARIC008
Member
Member # 27040
Reged: 12/03/02
Loc: Orlando, FL, US of A
Re: E4OD lockup Modification #1125120 - 03/16/03 04:14 PM Edit Reply Quote
Nice write up there. One thing that i think would be nice would be to have a three position switch. One postion be off, one position be on, and one position be automatic, like you never even cut the wire and added the switch. That way when someone else drives your vehicle you can leave it on the automatic position and let the trans take care of itself and when you drive it toggle between off and on.
EPW
1992 E-350, 7.3idi, Future wanted modifications: Banks Sidewinder Turbo, 5400 degree Kelvin HIDS, BTS Transmission.
why I don't have the modifications: Me's be poor.(Pictures}
Post Extras:
BossTrans
Member
Member # 27254
Reged: 12/08/02
Re: E4OD lockup Modification #1125633 - 03/16/03 09:21 PM Edit Reply Quote
I agree that if all the electronics work then a 3 position switch would be the hot setup. Ours was not the case. Somewhere in the vehicle is a bad ground so at this time we wanted lockup off or manually on because the computer was pigging up the cycles. The real hot setup would be a lighted toggle switch which glowed green when lockup was off. Or if prefered a normally off light unless the light was grounded and then to glow red or amber alerting the driver to its manual presence and reminding the driver, Hey Here I am!!! Shut me off before you stop!!....
Dan....
