e250 Vacuum Canister and vacuum issues
jayro88
Auburn IN
So a while back my vaccum pump froze up and died. Prior to that I had no vacuum issues. I replaced the pump, but it never seemed quite right. When it was really cold out my brake light would come on at idle and my peddle would be hard. Since everything was fine before I thought it might be the old hose coming off the vacuum pump had a tear or wasn't sealing correctly. Yesterday I went ahead and replaced the hose and put clamps on each end. I am still having the vacuum issue. I have ordered another replacement pump to install and am thinking that maybe the new one was bad/weak out of the box. While I am at it I was thinking of maybe replacing the vacuum reserve canister (looks like a coffee can) that is located in the passenger side fender next to the battery. A quick search isn't bringing up a stock replacement. I found some universal replacements, but I was wondering what everyone else is running?
riphip
Memphis, TN.
Plug the tube going to the coffee can and see if brakes work better first. May be the vacuum switch
BrianX128
Pittsburgh
I got an old one from wes, but literally anything you can seal off will work so as long as you can adapt a universal one to the plugs and hoses you'll be fine
jorge140
